Found a wire that puzzles me...
'afternoon all,
I was wiring a towbar in yesterday and came across this yellow wire with a female, blue connector that was a permanent live.
It was taped up against the loom and looked like it was there since the loom was fitted.
Out of curiosity I wondered if anyone knew what this is for?
[attachment=17998]
[attachment=17999]
Does everything work? If so dont worry. But at a guess they use the same wiring harnesses on sevral models abroad or.not. Wires just not connected in this country/model
thats interesting where abouts was it? is it perminant live or switched live as it may make a good charging point for a emergency torch Wink
My thoughts aswell cully got one I've been meaning to wire in for a while
(29-07-2014, 03:55 PM)cully Wrote: thats interesting where abouts was it? is it perminant live or switched live as it may make a good charging point for a emergency torch Wink
Hi Cully,
Wire is located in the off side rear, under the plastic above and to the right of the parcel shelf that the loom hides under.
The keys were out of the ignition when I tested the wire.
hmm that is interesting.. permanent live to the rear of the vehicle, cant think what it would be for,.
/Toseland
the loom is fitted with different models and extras in mind..if everything works then well we all find the odd wire in all our cars
Anything like a rear alarm sensor? What power was it giving ? 12v?
Strange wire, i think my portuguese 306 doesnt have this wire or i never saw it
It will be good for a 12v permanent charger Wink
12v for running a fridge when towing a caravan. For use with 12 pin trailer socket maybe.
Its not anywhere near where a boot light may be? The little rectangle ones that come on when the boot opens? Looks like an identical plug to those used in the 106s
Maybe its something crazy for the euro spec models and something we didnt get in the uk.
The boot light is on the other side. Wonder if its moved over for lhd models? Can't see why it would be though!
  wire identification pug306driver 0 2,222 04-12-2019, 10:53 AM
Last Post: pug306driver
  Wire thickness for cooling fan philpemberton94 3 3,268 17-04-2015, 04:47 PM
Last Post: philpemberton94
  Random Wire Off Starter Eddleston 3 3,523 03-12-2014, 04:42 PM
Last Post: Niall
