27-07-2014, 01:17 PM
Thinking about converting to bosch soon, is just a matter of swapping the pump, lines and injectors? Or is there any other parts i need to make sure i have?
Cheers!
Cheers!
No smoke, No poke!
bosch pump parts
Cheers!
No smoke, No poke!
27-07-2014, 02:42 PM
That's it, and you'll need the bracket and Bosch pully. But that's it
![]() TEAM CONROD SHITTING RALLYE!
27-07-2014, 03:06 PM
Arent the brackets interchangeable, ie one set of holes are for bosch pump and one set fit lucas
27-07-2014, 03:11 PM
(27-07-2014, 03:06 PM)Nath140889 Wrote: Arent the brackets interchangeable, ie one set of holes are for bosch pump and one set fit lucas Yup ![]() Worth mentioning its best to perhaps to cambelt at same time...water pump with it if you can afford to. All for peace of mind and getting two jobs in one done
28-07-2014, 08:15 AM
You have to extract the studs and move their position for each pump dont you?
Done the cambelt less than 5k mile ago ![]() Cheers for the help guys, will be the next purchase after a front mount!
No smoke, No poke!
28-07-2014, 08:47 AM
If it's had a recent cambelt kit just buy the belt around £20
28-07-2014, 10:54 AM
The bosch and front mount will be bought within a couple of weeks of each other and probably going on within a few days of each other, just getting parts together for the time being
No smoke, No poke!
29-07-2014, 09:55 AM
can confirm the stud location is slightly different for the lucas
youll see once you take th elucas pump off that there is another set of holes on the bracket itself, just remove each stud and put it in the hole next to it or your timing will be diabolical. easy. Given the choice between Niall and the sheep. I would choose the sheep!
/Toseland |
| Slack in bosch pump? | dt_ | 14 | 12,185 |
21-10-2020, 03:41 AM Last Post: dt_ |
| Bosch pump help for newbie | PugRy | 2 | 4,574 |
05-01-2020, 09:09 PM Last Post: jamie182 |
| Bosch pump fuel screw broken | Forby | 0 | 3,171 |
12-03-2019, 06:47 PM Last Post: Forby |
