in need of a switch...
Basically i want a switch to manually turn the fueling ON when the ignition is live, a sort of very basic immobiliser,
now.. this switch i want to be special, essentially i want a switch like the one below but that only stays on if there is a live going to it (ie the ignition is on) and when the ignition is off it resets to the off position (so i have to turn it on again when i get back in the car). is this possible or is it possible to do this some way?
so... ignition on, switch on, start... ignition off, switch resets to off, ..
hopefully my screwed up mind made myself somewhat clear.
/Toseland
Perfectly clear, almost like the ignition off trips it back. Sure there is something out there
Ideally i want to have a set of switches in the vitara, those little silver metal toggle ones, on the center console,
Fans, spotlights, ignition, glowplugs, fuel and possibly even start...
with a battery isolater for sexy show, all mounted on a nice simple elegant stainless or aluminium panel in place of thhe clock..
/Toseland
That will look sick. Cully is probably best to have words with, he knows his shit when it comes to this stuff
using a relay to latch a switch when Ignition is on after pushing start button
[attachment=17988]
