engine bogging down when coming off throttle
Ok.. symptons..
when you give it the beans, if you let it drop off of the loud juice and fall back to idle itll bog for a split second (like you try to pull away in the wrong gear), chug once or twice, before filling itself back out to a nice smooth idle..
its as if the revs fall a little too far then pick back up again.
Bosch pump
LDA ground (although i am not sure how aggressively)
Gov. modded
no smoke when idling but some on full boost, fiddled with the compensator to reduce this and now it only coals if i mat it out of boost...
other than this it runs sweet as a nutt..
any ideas?
/Toseland
Two issues,
either your pump is emptying due to lack of fuel supply to it, or your anti-stall spring is not setup properly and not kicking in when your idle drops too low.
it will likely be the anti stall spring as i have new 3/8ths fuel pipe throughout...
where be le antistall spring and how to set it up!?
/Toseland
  Rattle coming from Throttle Arm (on Bosch) silverzx 65 35,373 01-05-2012, 10:26 AM
Last Post: Garlicbread
