For Sale: 1.4/1.6 Nissin Alloy radiator.
As above, pictures to follow shortly, radiator to fit 1.4/1.6 models - this is the wider radiator for air con models so a good upgrade for any cars with the smaller rad which have had some tuning work. (I have a top hose and clamp you can take with it that allows it to be fitted to the ones with smaller rads if required).
It's about 2-3 years old and in great condition, perfect inside as I acid flushed all the engine side out before fitting and it's always been run with the correct mix of red antifreeze in, no visible internal corrosion at all.
£20 ono
[attachment=17935]
[attachment=17936]
£15 to shift it, cost me a lot more than that.
  Used Nissen Alloy Radiator eddy_gti6 0 1,450 23-05-2014, 04:56 PM
Last Post: eddy_gti6
