Breaking VLR 306 GTi6
If I can get enough interest in parts I will break the 306.
Looking to sell my VLR 306 GTi6
Oct 2014
Tax - Sep 2014
Mileage - 118k+ use the car day to day
Engine was rebuilt around 1000 mile ago on 5th April as you can see on my project thread. New head gasket, head bolts, water pump, cam belt kit, exhaust gasket. New inlet gasket was fitted about a month ago when the VLR was fitted.
spec:
Bare engine with catcam 3107s, XSI engine mount everything removed from aux setup so only runs an alternator done 3000 mile since head gasket, timing belt and water pump were replaced. I have an inlet with no TB I will include as well - £350
Maniflow manifold with Magnex group N exhaust - £250
VLR BTCC inlet manifold with throttle body and cold air feed and modified slam panel - SOLD
Omex 600 ecu with custom loom - SOLD
Billet Lightened & balanced Flywheel - £160
Alloy crank pulley - £50
BakerBM group N engine mounts with group A fork bush - £75
GE short shift - £15
Mocal 13row oil cooler - £80
Pugsport alloy gear linkages - £40
Gaz GHA coilovers with spoox adjustable top mounts (needs new bearings in top mounys what are £20 from spoox) - £250
Pugsport solid axle mounts - £100
Bilstein B4 rear shocks - £40
Pro race 1.2s - SOLD
288mm brembos with braided lines - £200
Rallye blanks - SOLD
Carbon coilpack cover - £70
AEM Wideband - £100
Oil pressure Gauge & volt gauge with carbon cd blank- £35
205 gti cooling system with 106 diesel header tank - £100
106 electric power steering with pipes - £50
Grey masked headlights - £50
plenty more to add...
[Image: 20140615_204956_zpsgkcrwlso.jpg]
[Image: 20140615_205203_zpsb8sgfesb.jpg]
[Image: 20140615_205325_zpshk9hrgmx.jpg]
[Image: 20140606_140142_zpsdhx14f32.jpg]
[Image: 20140607_121601_zpstzrpjanc.jpg]
Interested in rear shocks
maybe interested in the 106 PAS setup Smile
potentially interested in engine mounts and crank pulley.
Wish I had money for so much more.
Probably a silly question but do the brembos fit under lasers?
Need 16s as a minimum for brembos
Not sure if brembos will fit under lasers, probably not without spacers but im running them under 15" pro 1.2s
The brembos need 20mm spacers to go under cyclones IIRC
oil cooler plate thermostatic?
Yes mate thermostat sandwich plate and 13 row cooler
(20-07-2014, 10:34 PM)eddy_gti6 Wrote: Yes mate thermostat sandwich plate and 13 row cooler
perfetct - deffo interested in this then if you decide to break
Yes mate the car is now being broke
How much posted for the flywheel and crank pulley mate?
Both sold sorry
Dammit haha
  BREAKING - Diablo GTi6 93,000 miles Dangti6 15 11,355 25-07-2017, 12:51 PM
Last Post: Dangti6
  GTI6 Breaking OXY mspdan 8 6,594 10-01-2017, 07:44 PM
Last Post: mspdan
  GTI6 Breaking - Suffolk Silky 12 8,078 24-03-2016, 08:42 AM
Last Post: Silky
