clutch problems
I havent used my 306 for about 2 weeks due to being of the road when I was driving the clutch pedal has gone stiff before it went of the road its was smooth can anyone help thanks
Check for a little spring on the pedal, if it's still there, remove it. There's a guide in the guides section if you're unsure
(10-07-2014, 02:59 PM)Midnightclub Wrote: Check for a little spring on the pedal, if it's still there, remove it. There's a guide in the guides section if you're unsure
Cheers mate
No probs
Agreed on the spring idea, the first thing i did when i got my estate was sack that spring off! lol
Try just using it a bit, may just be a bit dry in spots.
push pedal to floor and slip your foot off so it smashes back up
Do that a few times auto adjuster in cable may have seized up a little with it been stood
Team Doesn't own a 306
(11-07-2014, 10:57 AM)Danny2009 Wrote: push pedal to floor and slip your foot off so it smashes back up
Thanks
  Could this be the root of my clutch problems stu9 7 4,682 25-01-2014, 09:44 PM
Last Post: stu9
