Threads: 40
2
Car Model/Spec: DTURBO
Given 5 thank(s) in 5 post(s)
Have the engine ready to be lifted out, goin to lift it with a telehandler
Question is wats the best setup with chains or whatever i use to make sure im able to tilt the engine to clear the chassis?
Also might do the head gasket while its out. Is tgere any way of knowin how many notches is on the gasket before lifting off the head?
HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Took mine out of the '6 tonight, just had a strap which was slightly shorter on the drivers side
Threads: 40
2
Yeah was thinkin that be tge way to go alryt.
You pull it out the front?
Threads: 164
25
Went up and over the aircon rad and fans but yeah out the front all in one go
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
A hell lot easier with one person controlling the lift mechanism (tractor) and one person guiding the engine out, I can imagine it being a bitch on your own due to gearbox needing a nudge toward the bulk head as it comes out.
