Threads: 210
1
Car Model/Spec: Ph1 White Gti6/306 DTurbo
Given 7 thank(s) in 7 post(s)
My car is all of a sudden making a knocking noise when I'm off the power or when I push the clutch down. It sounds like its coming from the engine bay but I'm not 100%, I can feel the knocking through the gear stick and the clutch pedal. Any one know what this could be? Like exhaust or something?
Threads: 142
58
Car Model/Spec: E46 BMW 320d
Gearbox...TU gearboxes are notoriously made of cheese. My 1.4 went through nearly 3 in its time with me!
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
05-07-2014, 07:41 AM
(This post was last modified: 05-07-2014, 07:42 AM by rocker8742.)
Cost me 300 when the box went on mine to have it replaced by a garage(did the clutch at the same time , could do it much cheaper yourself
Although mine didnt give any warning just pulled out of work there was a Big Bang and then any time you tried pulling away it would feel like something was wedged against the floor
Threads: 386
87
It could just be a simple driveshaft! Though the gearboxes are crap (one of my 1.4s was on its 3rd box at 70k miles!) they tend to whine for a while first, as does a dying release bearing. It's not always continuous noise as the force on the diff bearings is reversed when you're coasting.
Threads: 581
195
Yeah Tu boxes are notioriously bad. You could try an oil change/top up as a last ditch attempt but I'm doubtful. Also if it's knocking with the clutch down, it could well be the release bearing or pressure plate so it's box off time anyway
Threads: 386
87
Hmm, you could buy some lol. Its about £15 for 2 litres at the dealers.
If it comes out clean (no filings) and into a clean container you can re-use it anyway as it will have been changed when the clutch was done...just to confirm or rule out the gearbox. Or take it back to the garage and ask them to check it maybe?
Threads: 371
29
Car Model/Spec: ford fiesta
Given 82 thank(s) in 82 post(s)
How much? Love a good project. Also got a box hanging about at work sonewhere I think
