Breaking car - Prices lowered
All parts have already been taken off, and I am mid-way through checking the condition of things before I list them, so will have more to add in a week or so. I will add pictures shortly, and sorry I cannot type a pound sign with this keyboard!
Rallye seats. Good overall condition. Have photographed bad points. - 80
GTI front anti roll bar. No rust, painted red. Does have quite a few chips from fitting but still looks good. - 15
XUD front anti roll bar. Standard black paint, bit rusty where its flaked off, still perfectly usable. - 5
Xantia inlet manifold (Shortened one which doesn't touch MC). EGR system removed properly, i.e. cut open to remove channel and welded back up. Mating surface was then machined to get it perfectly flat and align the runners. One end has been filed down to allow a boost pipe between it and the head. Very clean inside. - 50
XUD Hoffman race tube. Only used for few miles because realised it had a pin hole, so still as new apart from the soot. Just needs a dab of weld. - 25
XUD decat pipe. Good condition. - 15
XUD middle section. Couple of pin holes near end. - 5
XUD drivers driveshaft. Very good condition (only done 5k) - 25
XUD drivers driveshaft. Good working order, inner boot has cracks but only small not all the way through. - 10
XUD various engine gaskets from a head kit. - Free to collector
XUD flywheel. Surface rust, just needs clean up. - 10
XUD rocker cover. Just been blasted so incredibly clean, looks brand new. - 10
XUD steel sump. - 5
XUD lower mount cradle. Rubber in usable condition, no obvious cracks etc. - 10
XUD upper mount bracket. Comes with bolts to fix to engine and also the belt tensioning spring and cup. - 10
XUD cambelt covers. - Free to collector
XUD vacuum pump. Got 2 of them. - 10 each
XUD alternator crank pulley. Got 2 of them, come with the bolt and washer/spacer. - 5 each
Xud thermostat housing and fuel filter housing. Plastic water outlet piece broken. - 5
XUD power steering pump. Not sure if ph1 or 2 but can supply pictures. - 10
XUD starter motor - 10
XUD alternator. 70 amp. Phase 1 mountings. - 15
XUD PH1 Nissens rad. Great condition, barely used. - 25
XUD battery. - Halfords advanced battery with 4 year warranty, 100 new. Bought Jan 2013 and still have reciept. - 40
22mm master cylinder. Removed from my DT, think its what came on all non GTI models. - 10
Boost gauge. The smoked type which you wire up so it lights up. - 5
Dturbo emblem boot carpet and fitted mats - Smartens up the boot nicely, great condition. Footwell mats are black with white outline, all good condition, drivers obviously looks used. - 10
3 door side skirts. Astor grey, good overall condition but do have a few scratches from being stored. 25
Front arch liners. Free to collector
Cherry red grill and hockey sticks. Average condition paint, top left fixing hole broken on grill, few tabs broken on hockey sticks. - Free to collector
Crystal headlights. All clips intact on drivers side. Only the side clip on passenger side (has been through two MOT's though with just this and a cable tie the other side). - 15
Rallye bumper. Cherry red with splitter and rallye blanks. One mounting stud snapped. Hairline crack and a scrape on passenger side so needs paint (Photo taken). - 25
GTI-6 aluminium effect centre console. Few scratches and is cracked where the cigarette lighter fits (not visible). - 10
Will also have a FMIC setup, GTI front brakes and master cylinder, and parts from my sound system available soon.
Feel free to make offers. Collection from NR13, or I may be able to drive to meet somewhere/post at extra cost
[Image: 20120704_212316.jpg]
If I get my refund quick enough ill come pick the bosch pump up. But I need a refund from the one that got lost in post.
Interested in inlet mani, just a bit too expensive imo
Pm me if theres any movement on price
[Image: av5ym8.jpg]
Wind deflectors please mate, pugfest? Or failing that, ppcitp.
Interested in the driveshaft and mats pal, any pics of the mats?
No smoke, No poke!
(24-06-2014, 08:07 PM)bashbarnard Wrote: If I get my refund quick enough ill come pick the bosch pump up. But I need a refund from the one that got lost in post.
Oki doke just let me know
(24-06-2014, 09:33 PM)Jimbo Wrote: Interested in inlet mani, just a bit too expensive imo
I thought it was a reasonable price considering the work gone into it. Cost me £40 initially, £25 for the welding and £25 for the machining plus quite a bit of work cutting and cleaning the gunk out. I did however say offers welcome..
(24-06-2014, 09:45 PM)Poodle Wrote: Wind deflectors please mate, pugfest? Or failing that, ppcitp.
I'm afraid I'm not going to pugfest and I'm not yet sure about PPC. The usual lot aren't going this year but I may end up coming on my own, ill let you know.
(25-06-2014, 08:24 AM)philpemberton94 Wrote: Interested in the driveshaft and mats pal, any pics of the mats?
Ok, I do have a couple of pics which I will put on tomorrow.
Picks of the floor matts? I assume 3/5door is the same fitting?
(25-06-2014, 08:42 PM)Connor Wrote: Picks of the floor matts? I assume 3/5door is the same fitting?
Will add a couple tomorrow,and yes I assume so.
Rallye seats?
(26-06-2014, 12:20 AM)Matt Wrote: Rallye seats?
Assume that means you want the pictures, ill be adding some later this evening.
Heres the pictures of the bad points on the seats (using a 5 pence piece for size comparison)...
Burn in rear lower bench, drivers side, back corner of bench.
[Image: IMAG0948_zpsc317f4f1.jpg]
[Image: IMAG0949_zps33d7acc0.jpg]
Bolster wear
[Image: IMAG0944_zps821b4e4a.jpg]
Small bit that has been stitched by previous owner. I've used the seat for over 2 years so the stitchings definatly doing its job.
[Image: IMAG0942_zps5fcee473.jpg]
This holes so small it just looks like another bit of the yellow pattern.
[Image: IMAG0941_zps97e47054.jpg]
And heres the passenger handle missing the 'underneath' bit of plastic.
[Image: IMAG0940_zps8382352b.jpg]
Forgot to mention they have leather headrests as I prefered the look and also got fed up of how soft the rallye ones were! I do have the originals though.
Also for those who don't know the bolsters on these seats are closer together than most 306 seats so they hold you tighter.
Pictures of the manifold
[Image: IMAG0985_zps834efde4.jpg]
Where its been filed down
[Image: IMAG0984_zpsb9c41ff9.jpg]
Front face, bit of gasket left on but I'll take it off
[Image: IMAG0983_zps00d71ea9.jpg]
XUD alternator (70amp), painted silver. Phase 1 type mountings.
[Image: IMAG0981_zps27a87d8a.jpg]
Boot mat. Haven't got a picture of the floor mats yet, but I'll take some on Sunday.
[Image: IMAG0968_zps17f3c75e.jpg]
Let me know if there's any other pictures you'd like, I don't want to just put them all on because its taking ages and I hate computers!
what i do need, is that little pipe off the front of your inlet manifold..
was that custom or something that came with the part? mine kinks 90degrees and is a pain to get an intercooler pipe for as i want the intercooler in a different place.
/Toseland
Ill definitely have the floor matts, if you could get pics of them and they look like 5door ones
(27-06-2014, 10:58 AM)toseland Wrote: what i do need, is that little pipe off the front of your inlet manifold..
Its just part of the manifold, I thought they were all the same? I've owned 3 Xantia mani's and they've all had the same inlet. I don't really want to sell it seperatly I'm afraid as the mani would become a bit unsellable then
(27-06-2014, 11:46 AM)Connor Wrote: Ill definitely have the floor matts, if you could get pics of them and they look like 5door ones
I've just realised I didn't make it very clear in the advert, the floor mats are not 'dturbo' ones as well, they are plain black with a white outline.
I'll get some pictures in a couple of days.
Still got the boost guage? Any pics?
Only this one, I'm afraid I don't have a picture of it lit up. Lights up white, blue and red.
[Image: IMAG0993_zps50382486.jpg]
I can put some power through it if you want a lit up photo. Should be able to on Sunday.
Is it is psi or bar? What pressure does it go up to?
Its PSI and 30
yeah i wouldnt expect that, i dont have a xantia, engine, it is almost there with 1 or 2 minor differences.. (that being one of them)
/Toseland
[/quote]
What is your manifold from then? Could you put a picture up?
Bump. Few things added.
Would post race tube?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
(19-07-2014, 06:54 PM)HDIkyle Wrote: Would post race tube?
I will look into it during the week, not particularly heavy but awkward size so don't know how much it'll be.
Pics of the td04?
Here you go
[Image: IMAG0987_zps60980b40.jpg]
[Image: IMAG0988_zps598ddba9.jpg]
Bump prices lowered
Is that TD04 practically bolt on? If so, i'm very interested. PM me asap, thanks.
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
Looks like everything is there to me will just need a longer length of pipe for return
Team Doesn't own a 306
(26-07-2014, 07:34 PM)Danny2009 Wrote: Looks like everything is there to me will just need a longer length of pipe for return
If so, i'm interested mate, can you PM me details?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
Yeah as Danny says its bolt on apart from the rubber pipe. I just used a silicon bend, think it was around 18mm ID. I've replied to your message.
  breaking phase 1 d turbo bosch pump lowered wibbz 25 12,475 09-11-2014, 03:19 PM
Last Post: RetroPug
  Breaking: Breaking xud challangers lowered disk axle tdo4 Bosch fmic ect Danny2009 12 6,597 15-08-2014, 07:56 PM
Last Post: Danny2009
  FOR SALE: UPDATED! PRICES LOWERED! 306 DT XUD9 1.9 Parts Clearout! Ported+Polishd head, rad etc nollafnhoj 10 5,995 08-06-2014, 07:23 PM
Last Post: nollafnhoj
