View on Lucas pump (Veg)
Just wanted to no why everyone says not to run veg on a Lucas
There shit and will leave you stranded at the side of the road
People say that it ruins the seals in the pump iirc. Some pumps can run for years without a problem, whereas others will give up after a couple of weeks, if not days. Depends how lucky you're feeling as to whether or not you run veg on a Lucas really. Wink
Put it in and find out I hurd of a few people do it with out issue and other people put some in start it and pump shit it's self soon as it pulls it though, just have a bosch at the ready to stick on and go for it see what happens.
Hoping I'm one of the lucky ones as I ran out of diesel and had 40l of veg on the boot and just stuck 20l in seems to be running fine but I guess I should mix it really
Bosch is self lubricating Lucas isn't
Due to lack of lubrication pump could seize chuck cambelt off any hello new engine
Team Doesn't own a 306
So would it help if I put some 2stroke in to help the lubrication
maybe...
it would help it even more if you removed it and put it on the shelf...then fitted a bosch. the lucas pump wont stop you driving then ThumbsUp
lucas pumps make good door stops!
/Toseland
and paperweights too
It will fail, its just a matter of time, up until it fails, it will run perfectly Tongue
99% of the xud engines I see on cars for sale all have Lucas pumps. I'm yet to find one with a Bosch pump?! Is there a particular age or model that comes as standard with Bosch pump or was it totally random?
Ph1s much more common
think it was something like pre-96... peugeot are very much like the santana built suzukis in that respect.. what it should be, and what they had on the shelf at the time are always 2 very different things
/Toseland
  Lucas pump cap carlukepeugeot 7 8,848 19-11-2020, 12:14 PM
Last Post: johnny625
  Lucas pump timing probe issues weka 0 2,830 21-03-2019, 08:39 PM
Last Post: weka
  Need help d turbo lucas pump. Djbeny4477 1 3,452 21-10-2018, 05:15 PM
