Threads: 164
25
Car Model/Spec: Gti6
So while the engine is out of the gti what is it going to be worth doing
Cambelt + waterpump is obvious
Engine mounts
Check top mount cup
Gear linkages
Fluids and filter
Clutch
Anything else that will be much easier with the block and box out basically and anything I might forget for the swap
Threads: 386
87
Clutch cable, fork bushes and de-AC if not already done.
Threads: 58
3
Car Model/Spec: Loads
Degrease and remove rust unless your lucky and have missed out on the tin worm
Clutch cable as said and the bush's+shaft as these wear too and make a huge difference, AC is lovely in this and all weather's
Threads: 151
14
Car Model/Spec: 306 D-turbo
Clean the subframe so it's gleaming
Don't see it but makes it so much nicer to work on when your not covered in shit upto the arm pit
Team Doesn't own a 306
Threads: 226
24
Car Model/Spec: A3 TDi
Clean the bay as said, have a check of brake lines. Not doing headgasket?
Threads: 58
3
Threads: 102
18
Car Model/Spec: Ph.1 Gti-6 63k
Clean & paint absolutely everything!
62k Diablo Phase 1 Gti-6: Project Thread
