Stub axle??
Stub axle??
Hi all.
The o/s/r road wheel has more negative chamber than the n/s.
Ive look on ebay for complete rear axles but someone said at work
That its more likely to be a stub axle as 306s are apparantly prone for this
Issue. Can anyone shed some info as what to change first.
Many thanks.
Don't listen to that person in work... Its most likely the trailing arm bearings, one of the common faults on a 306 and a replacement beam will be your best bet
Replacement beam or a beam rebuild Smile Connor is right it will be the trailing arm bearings at fault
if the bearings have been buggered for a while it will have trashed the stub axle as well, the bearings are the thing that fail, but people don't check/notice the problem which then ends up ruining the stub axle too!
Easiest option is to replace the beam for a known good one or rebuild one using new parts Smile
Team Orange Engine Bay
I did wander about the rear axle. Ive never known a 306 with a bent stub axle. Ill try and source an axle or buy the repaair kit off ebay.
Will it say how to change the radius arm bearings in a haynes manual?.
I cant afford to buy a new axle so will rebuild my original one.
You don't need to buy a new one, just a decent second hand one which is ok, then you can take your time to rebuild your current axle. Then swap it back on and sell the second hand one back on
How much should i pay?. Money is abit tight this month.
Will it say in a haynes manual how to do the bearing
Have a read of this guide mate, it explains everything
http://www.205gtidrivers.com/articles.p ... beamrefurb
That guide is brilliant. Thankyou very much.
No problem mate, I found it useful too.....if Carlsberg did beam refurb guides this would probably be it lol
gareth7 Wrote:No problem mate, I found it useful too.....if Carlsberg did beam refurb guides this would probably be it lol
lol lol too right
  Rear stub axle sizes weka 2 3,972 26-04-2019, 06:18 PM
Last Post: weka
  Gti 6 stub axel LironTurbo 3 3,434 14-08-2017, 08:53 PM
Last Post: cully
  Rear stub axle pin L95 4 4,452 21-06-2016, 07:07 PM
Last Post: L95
