Abs light, stop light and air bag faults help
Air bag light has been on for a while
But on the way home from fcs the abs and stop light came on
Abs fault
[Image: F65527EF-DE80-47B5-84BC-C957A37498FF_zpszwhap6gz.jpg]
Air bag faults
[Image: 75CE9E59-2D3F-4A89-9F95-D8DE4B02254D_zpsigkzo2so.jpg]
[Image: 11181578-A97C-4E42-9E0C-3B773421DFA3_zpssokidpvv.jpg]
[Image: 5FF1F18B-9A9A-4CCF-95A7-41C37397C5DA_zpswftkr2vj.jpg]
any help will be greatly appreciated Smile
The airbag faults will be related to the dodgy pretensioner cables under the seat. Pm cully for some of his resistors or have a search for how to do it yourself.
ABS is the rear wheel sensor, replace with new
HDi Cabby Project Click
I'm not sure that it the ABS sensor? Looks more like the ABS unit at fault unless I'm reading it wrong?
Says right hand rear wheel? Sounds sensor related to me!! lol
Right hand rear wheel inlet/outlet solenoid valve...the valves are in the unit that stop or allow fluid to give the brake pumping effect.
I think that's unrelated http://www.206info.co.uk/Forums/viewtopic/t=50040.html
I would clear the codes, take it for a blast and rescan. Might be worth putting it on pp2k to be sure
That is the problem of generic fault codes lol. PP would be the way to go tbh.
^ Agreed
When I searched that code on google it said it was a switch for the break pedal ?
Search long enough it gives about 5 or 6 different things lol.
Get some proper diags on there and try again.
  Engine light always on and had slight run-on CaptainHair 0 2,900 02-07-2020, 08:54 PM
Last Post: CaptainHair
  Engine management light came on ,, 306 hdi barnesy213 10 9,817 25-05-2016, 07:08 PM
Last Post: DeeTurbo
  faults pug306driver 3 2,867 08-04-2016, 02:55 PM
Last Post: pug306driver
