15-07-2014, 05:18 PM
I have the same issue in the gti,
Wheel wobble annoyance :(
15-07-2014, 05:52 PM
15-07-2014, 08:02 PM
P bushes, front bushes, inner rods, out rod ends, drop links, top bearings....
All were new 10k or so ago or replaced recently...and they are all rock solid, no play anywhere. But I have said that a few times already!! Wishes for more power...
06-08-2014, 08:59 PM
So all taken apart, checked, replaced both driveshafts....
Still a vibration through the car above 65 Wishes for more power...
06-08-2014, 09:10 PM
Are your wheel bolts done up? Should be part of your pretrack check list just in case you dont know.
07-08-2014, 08:06 AM
Is there anything left that you haven't checked or changed now?
07-08-2014, 08:30 AM
Have you checked for play in things with it NOT being jacked up? Sometimes the weight of hub etc can mask the play..
08-03-2015, 10:02 PM
I have swapped my front discs and pads due to discs being warped and ever since I've had a wobble. Only slight on gentle acceleration but at 65+ it's alot worse. Lime a drive shaft. Stripped the brakes and found the hub flange to have a bulge.. tried grinding g flat but still wobbles... New flange and bearings I guess
Wheel wobble/play | mcglynn | 11 | 2,228 |
04-10-2014, 08:52 PM Last Post: mcglynn |
Acceleration wobble | sherman306 | 7 | 2,230 |
07-08-2014, 01:35 PM Last Post: Janne L |
steering wheel wobble | dadaddy35 | 2 | 1,182 |
04-04-2014, 03:42 PM Last Post: Toms306 |
