Head bolt differences?
Headbolts...
Do the headbolts from the XUD7 fit the XUD9?
my local motorfactor is adamant that they are the same, BUT when comparing them side by side,
The XUD9 bolts are approximately 150mm, and there is a 25mm spacer on the bolt itself,
the XUD7 bolts are 124mm, total length..
as it happens, the bolts total length is a tiny tiny bit over the length of the XUD7 bolt without the spacer (flange is at the same position)
same thread, pitch, etc,. same T55 head.
any issue with fitting these without the spacer? (XUD7 to the XUD9)
/Toseland
Do the original xud7 headbolts use a spacer or washer? These are vital if they do
no they didnt, the original XUD ones do,. and the difference in length is the size of the spacer
the XUD7 bolts did NOT have the spacer, and are 124mm long
the XUD9 bolts in there at the moment are 148mm long, and have a 24mm spacer.
/Toseland
Personally I would get the right bolts with the spacers. Aren't the spacers for ensuring that the torque is applied correctly?
HDi Cabby Project Click
When I stripped down a XUD7 I noticed the bolts were shorter as you say without a spacer.
Stage 2 XUD Sedan
  NAD differences, XUD to DW8 Orta 14 8,479 13-10-2015, 10:05 AM
Last Post: mr_fish
  Xud into partner van. Differences, and wiring help!! Matt 32 23,270 16-12-2014, 03:03 PM
Last Post: welshpug
  Sump Differences?? sweeney1987 9 5,316 11-08-2014, 07:20 PM
Last Post: Jonny81191
