Threads: 11
Given 0 thank(s) in 0 post(s)
Hi. If I fitted the whole kit ,ecu ignition key bsi ,transponder from the same car would it have to be programed in for it to start or will it start OK thanks.hope this makes sense p/s all the numbers are the same as my car .
Threads: 476
81
Car Model/Spec: 306 Rallye
I think thats everything. I have no idea but im sure someone will be along shortly. I believe youd need the door locks too?
Threads: 11
Oh yer got them to thanks.
Threads: 11
Cheeers for that they, but will it need any progaming in or will it start up no probs ta .
Threads: 476
81
You've swapped everything and everything matches so nothing should need reprogramming as far as I'm aware.
Threads: 386
87
03-06-2014, 10:22 PM
(This post was last modified: 03-06-2014, 10:22 PM by Toms306.)
As Rowell says, as long as you change all the coded parts together they will not need recoding.
Threads: 11
Many thanks can't wait and try it tomorrow good news ,great site .btw
