Bleed nipple sizes
Bleed nipple sizes
Im changing the rubber brake pipes on my 306 hdi. Also 2 nipples on the rear calipers will have to be drilled out and redone by some people I know cause they snapped with old age.
The rear ones Im not sure yet untill there drilled out depending on the condition of the calipers. If there not the best I get anther set.
I got the front nipples loose but there warn. I would like to fit new nipples on the front calipers. What sizes are the
standard nipples on the 306 hdi front caliper?
thanks.
Welshy_Pete Wrote:Im changing the rubber brake pipes on my 306 hdi. Also 2 nipples on the rear calipers will have to be drilled out and redone by some people I know cause they snapped with old age.
thanks.
peugeot dealers should be able to get them in...
i could find out the spanner size but the ACTUAL nipple.. pass
Decs nipples are free.
bahaha!
306 HDI, soon to be XUD
I don't want to know about Decs nipples! Confusedhock:
Team Orange Engine Bay
Front nipples are 8mm, yes i know my nipples... And yours Wink
Mmmmmm nipples
I got the bleed nipples removed for £12 each caliper. Also found 2 brand new nipples I had spare which fit perfect. So thats anther job done.
What size are the rear caliper nipples im looking to buy a pair for mine.
  Any tips for undoing rear bleed nipples on calipers? Tom85 18 7,928 27-06-2016, 07:39 PM
  Removing broken bleen nipple/How many types of rear calipers? Iaitoo 16 7,761 31-03-2016, 02:25 PM
Last Post: pug306driver
  Brake Bleed Nipple Specs Toms306 16 8,036 22-01-2016, 05:21 PM
Last Post: Toms306
