T2
T2
Ok just fitted a t2 doesn't seam to boost more than 10 psi why would this the boost pipe is on 100 precent ?? I hear like a bit of a whistle but not sure if thats the turbo as no airbox on the car ?
Have you adjusted the wategate actuater or turned fueling up
Yea fuel pump is a lucas its near maxed turbo no may e a boost leak from manafold nee gasket put on
Nee gasket? Meaning no gasket?
If so thats why.
Search is your friend, so much stuff on here about what you are asking about.
I knew nothing about XUDs until I started searching old threads and learned enough to do a pump and turbo conversion without asking too many silly questions just by using search when I got stuck.
New gasket
Iv tryed everything i think and still dont understand it
If your confident there is no boost leaks, are you sure the turbo is boosting? Do you get chronic coal out the exhaust?
could there be an oil feed issue and the turbo is now gone tight?
Yea turbo boosting 8-10 psi and yea black reek
if your 100% positive there is no boost leaks and you are getting chronic coal i would say the turbo has gone tight, due to no oil. when i done a turbo change on my xud, i had oil problems which meant the turbo wasnt being lubricated and caused the turbo to not spool at all, felt like i was driving a nad, and i had so much coal dropping out the back. i would suggest dropping the engine off the mount again, take the air intake pipe off and see of you can get your hand down by the turbo and spin it, if it doesnt spin freely then thats your problem
Yea trydd that and the turbo spins 100 precent like could it need a oil change as oil looked like jelly lol
aright, well it wouldnt hurt to do an oil change, do it and see if it helps. have you tried adjusting the wastegate on the turbo?
^^ignore that about the wastegate, just read an earlier post
Yea think so like but standard should be 14 psi should it not ?
standard ranges from 12 to 14 psi
Ahh im getting 8 max like and pure reek out the back its bad though lucas pump is screwed alot
what sort of exhaust have you got on the car? is it fully straight through? a blockage in the exhaust could restrict the turbo from spooling properly
Full straight through
dont know if you've come across this on your search http://www.aa1car.com/library/turbo_repair.htm
No havnt
Perhaps turn the fuel down abit? It might just be bogging down to much..
I had a kkk03 with same setup and it went far better just after sticking wastgate closed and bocking actuator pipe and its still not running write could that be true its screwed at pump to much even though before it was ok unless this turbo cant handle it ?
no mate..
Maybe oil is bad other than that i give up
(28-05-2014, 08:21 AM)pbell283 Wrote: Maybe oil is bad other than that i give up
wastegate needs adjusting or boost leak . . . .
Ok i cut the actuator pipe and put a screw in it do i still need to adjust the bolt on the wastgate arm to close the wastgate ?
(29-05-2014, 05:10 PM)pbell283 Wrote: Ok i cut the actuator pipe and put a screw in it do i still need to adjust the bolt on the wastgate arm to close the wastgate ?
without being rude mate you need to do some reading up is what you need to do . .Smile
I cant find anything
