24-05-2014, 09:21 AM
Would lucas fuel pump screwed too much cause a turbo not to work right i put a t2 on and its boosting 8psi but my lucas fuel pump is nearly right out if i screwed the turbo will that work ?
24-05-2014, 09:42 AM
tighten the wastegate on the turbo,did you replace the gaske when you changed the turbo?
24-05-2014, 09:43 AM
No didnt and il do that to waste gate
24-05-2014, 09:46 AM
i doubt it is wastegate to be honest, you've probably got a manifold boost leak, they're only like 6 quid, you should have changed it really.
24-05-2014, 09:47 AM
Yea wont be that but i could screw it more ? Its a t2
24-05-2014, 09:50 AM
(24-05-2014, 09:47 AM)pbell283 Wrote: Yea wont be that but i could screw it more ? Its a t2 try and voice your questions a bit better mate, you're hard to understand...
24-05-2014, 09:54 AM
If i screwed turbo more would it boost harder with the leak ?
24-05-2014, 10:05 AM
Nope.
24-05-2014, 10:16 AM
(24-05-2014, 10:05 AM)pugmanxud Wrote: Nope. This. If you wind the turbo up more, it'll just leak more. Your best bet will be to change the gasket.
25-05-2014, 01:25 PM
Il do that didnt relise how much boost u actually loose strugling to get 5 psi
28-05-2014, 02:43 AM
you remember to reconnect the pipe going to intercooler from pump?
28-05-2014, 08:24 AM
Yea everything is on ect
Lucas pump cap | carlukepeugeot | 7 | 3,775 |
19-11-2020, 12:14 PM Last Post: johnny625 |
Lucas pump timing probe issues | weka | 0 | 1,299 |
21-03-2019, 08:39 PM Last Post: weka |
Bosch pump fuel screw broken | Forby | 0 | 1,493 |
12-03-2019, 06:47 PM Last Post: Forby |
