Would lucas fuel pump screwed
Would lucas fuel pump screwed too much cause a turbo not to work right i put a t2 on and its boosting 8psi Sad but my lucas fuel pump is nearly right out if i screwed the turbo will that work ?
tighten the wastegate on the turbo,did you replace the gaske when you changed the turbo?
No didnt and il do that to waste gate
i doubt it is wastegate to be honest, you've probably got a manifold boost leak, they're only like 6 quid, you should have changed it really.
Yea wont be that but i could screw it more ? Its a t2
(24-05-2014, 09:47 AM)pbell283 Wrote: Yea wont be that but i could screw it more ? Its a t2
try and voice your questions a bit better mate, you're hard to understand... Smile
If i screwed turbo more would it boost harder with the leak ?
Nope.
(24-05-2014, 10:05 AM)pugmanxud Wrote: Nope.
This. If you wind the turbo up more, it'll just leak more. Your best bet will be to change the gasket. Wink
Il do that didnt relise how much boost u actually loose strugling to get 5 psi
you remember to reconnect the pipe going to intercooler from pump?
Yea everything is on ect
  Lucas pump cap carlukepeugeot 7 9,021 19-11-2020, 12:14 PM
Last Post: johnny625
  Lucas pump timing probe issues weka 0 2,894 21-03-2019, 08:39 PM
Last Post: weka
  Bosch pump fuel screw broken Forby 0 3,206 12-03-2019, 06:47 PM
Last Post: Forby
