XUD conversion help!
Just trying to get the revs to work on the cabby after I've converted it to XUD, obviously the petrol dials run via the ECU. Anyone who's done a similar conversion know how to get them working? I thought about swapping the clocks, but I'm not convinced it'll work..
Pretty sure Ruan said you need to swap the clocks. I still havnt got round to sorting mind yet.
Stage 2 XUD Sedan
Ph2 dt clocks needed
[Image: av5ym8.jpg]
Ill get my AD laptop out tomorrow and look it up for you mate if possible Smile
I'll swap the clocks and see if it fixes it..
(22-05-2014, 07:19 PM)Jimbo Wrote: Ph2 dt clocks needed
Hmm i don't think so; i 'think' i took ph2 dt clocks and put them into the GTIDI and it didn't make a huge amount of difference...
I know u need them when converting from hdi, which uses an ecu signal. Just gathered it would be the same
[Image: av5ym8.jpg]
Swapped them over and it all works, job jobbed!
