help bosch pump leak.
Hello my bosch pump is leaking from under the throttle arm is meeting the pump. Can this be sorted and if so is it easy. Its not that much now but presume it will get worse soon. Thanks
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
read the gov mod guide in the XUD section, tells you what you need to know . .Smile
  Slack in bosch pump? dt_ 14 12,183 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,573 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,171 12-03-2019, 06:47 PM
Last Post: Forby
