Threads: 117
21
Car Model/Spec: needs bwarrrp.
Given 1 thank(s) in 1 post(s)
right. it sounds like my rear beam is shaged on my ph3 1.6. how easy is it to replace? and i was thinking about putting a 6 beam on whilst im doing it. how hadr is it to trasnsform it from drum to disk. and will the thicker torsion bar give me better handleing? what price should i be paying for a second hand beam? thanks all.
Threads: 448
51
Easy to swap. If your swapping to disc you will need new handbrake cables. Tbh I wouldnt pay more than £80 for a decent '6 beam. Changing is easy too. Drop the old one off, something like 4 bolts either side. Then new one one, do the cables and bleed brakes
Threads: 117
21
Mint. Sounds easy enough that. Cheers matt.
Threads: 138
72
Car Model/Spec: Mincebus
Given 0 thank(s) in 0 post(s)
Check out the below. Dunno if they do them on an exchange basis, but speak to em. Might be worth going the full hog with a gti beam if youre doing it anyway...
http://www.imaxle.co.uk/catalog/refurbis...r-axle-306
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 150
14
Car Model/Spec: 306 HDI
personally i would just grab one from the scrappy, easy, cheap, job done
306 HDI, soon to be XUD
Threads: 23
0
Apart from you dont know what you are getting. Buying a refurbed one is a sure way of knowing that your new beam is good.
Also dont forget to remove the backbox before you drop the beam...
TEAM TRACK CAR + An E60 530d M-Sport for the daily
Threads: 374
38
Car Model/Spec: GTI 6
also lobbs video on the tubes of you - rear beam change..
Threads: 476
81
Car Model/Spec: 306 Rallye
declantg Wrote:personally i would just grab one from sams house, easy, cheap, job done
corrected for truth!
Threads: 150
14
SRowell Wrote:declantg Wrote:personally i would just grab one from sams house, easy, cheap, job done
He's right you no!
Threads: 117
21
Right, ivebeen told it might be the Barings. Could this be a possibillity.
Threads: 9
19
Car Model/Spec: Ph2 DT with big Snail.....
Given 3 thank(s) in 1 post(s)
kingy Wrote:Right, ivebeen told it might be the Barings. Could this be a possibillity.
Yes it will be the bearings, thats what goes on them normally but they are £80 a set and a bitch to change plus if its been like that for a while the stub's will be fecked too............
in short, be easier if you can get a know good, used one or if you can stretch to it better still with a re-con beam, but they aren't really cheap!
Threads: 374
38
again, the effort of changing bearings, you could remove and replace the beam...
Threads: 171
46
Car Model/Spec: Black 3dr Dturbo
ginge191 Wrote:kingy Wrote:Right, ivebeen told it might be the Barings. Could this be a possibillity.
again, the effort of changing bearings, you could remove and replace the beam... And get a 6 beam on there and maybe some thicker tortion bars
Threads: 92
43
Car Model/Spec: Tracterrrrrrrrr
Given 2 thank(s) in 2 post(s)
But... who's to say the replacement beam doesn't have 1,000miles left in it? Might be fine when you buy it, but go again soon /justsaying
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
