Gasket for EGR blank
Hi all
Bought an egr blank from eBay (made out of stainless steel and rumbled for smoothness.) Fitted it yesterday but realised after I hasn't put any gaskets on it. I just slid it in (wasn't much room to separate the flexi pipe from the inlet) and tightened it up. I don't think it is leaking, any way to tell?
Thanks
I bought the same one but never fitted. Should be able to use some gasket sealant on it if youre worried.
I got that one off eBay too, slotted in, no gasket either. Tbh I can't see any big problems with it, even if it is letting by it'll only be into engine bay as it's serving its purpose it's a big ass flat faced blockage in the middle of the pipe stopping the gasses travelling through. Have you also removed and blocked the vac line too?
I had already blocked the vac line. It all seems ok so I think I'll leave it for now. The inlet elbow gasket is leaking oil a bit (common problem) so I think I'll just wait until I do the gasket on that and maybe put some instant gasket on the blanking plate.
Thanks guys
  egr blank fgrc76 12 6,432 24-04-2015, 10:54 PM
Last Post: Iceman299
  manual boost controller and egr blank plate fitting, please help dirtyboost89 6 4,327 02-03-2015, 11:50 AM
Last Post: dirtyboost89
  EGR Push in type blank? pugdan95 5 3,872 09-01-2015, 07:21 PM
Last Post: doski
