4007 Twin piston calipers
For Sale
Twin piston brake calipers and carriers off a Peugeot 4007
Both pistons are on the same side of the caliper meaning that you wont have wheel clearance issues unlike brembos
The calipers are threaded and the holes are 130mm apart so they wont be a straight fit but all you need to do is make a bracket out of a bit of MDF and any engineering firm will be able to copy it into aluminum. Baker BM quoted me £50-£100 to do this
These could make epic OEM looking brakes for someone looking for a project.
Im looking for £100 for the pair of calipers
Pic off service box as I dont have a good one of them.
[Image: 00065917.jpg]
[attachment=0]
Service box pics won't work unless you're logged in
Aww Fuk. Ill save as then upload
Done, Cheers for letting me know
How big are the discs for these?
Standard are 294mm iirc but theyer 5 stud.
I was gonna use 302mm discs.
Dum-Dum Wrote:Both pistons are on the same side of the caliper meaning that you wont have wheel clearance issues unlike brembos
Thats because Brembos are 4 pot calipers, not two
[Image: c6769879.jpg] TEAM TRACK CAR + An E60 530d M-Sport for the daily
Anyone even remotely interested in these before I stick them on the 6 forum?
unless they'd fit behind 15 inch speedlines :| ?
Well i reckon that if you drilled the mount to an 80mm spacing you could maybe use GTi6 discs but ive not tested it.
  283mm front calipers, and rear disc calipers Sambarker 2 2,416 12-02-2015, 02:15 PM
Last Post: Piggy
