306 bits / 306
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
Wanted: 306 bits / 306
Basically I'm after a 306 xud9 engine all auxiliaries running bosch pump and a t2/k14 if possible but not essential. Cheap as possible. Doesn't matter if head gaskets gone or something minor. Will be rebuilding with new rods as well to go.in mine so even a dhy is fine. Rather build it off the car then swap it in a day. Again cheap as possible not spending silly money I'd rather wait for a scrap one to come up if that's the case of being expensive.
Im doing mega miles atm. Anyone got anything to help me out? Cone on got to be sonething out there?
Ozone has a lump with a bosch
I'll have the k14 off the 205 in a couple of weeks. Very little just needs wastegate sorting. It's yours when I see you next if it helps.
Even if its just pump lines and injectors atm to. My turbo will have to wait. Just need to start running veg. Im between ipswich and bury so a local one would be nice thats full of diesel Smile wheres ozone live?
