Rear beam brake lines
Right now I've got my caliper bolts I'll be changing everything over,
But I have a drum beam on the car, and a disc beam with minimal amounts of brake lines attached.
Anyone got any information of which lines to disconnect, where to disconnect from and what goes where,
I've got the load spring thing and that has 4 ports so need to know what each one does, an here it goes etc.
What size unions do I need if I do make up likes as I can see there are two sizes that go into the load compensator.
And anyone got a decent picture of the beam? With all brake lines attached so I can see where the lines run and which ones I might have to make up
  Rear beam ...the good and the bad Mighty306 35 31,864 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,463 26-06-2020, 07:19 AM
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,238 18-04-2019, 10:14 AM
