Phase one interior
Basically I should be buying a phase one next.month or soon after next month for the engine and bosch pump etc. Thought I'd change the dials and interior bits and bobs to. Anything I need to.know when swapping?
Ph1 clocks have a cable driven speedo, the plug ends on the electric window switches are also different although you can swap the door loom easily enough, and the door lock pins are different
So all I'll have to do is run the cable from the engine gearbox I'm putting in. I have keep fit windows.
(12-05-2014, 02:21 PM)ozonehostile Wrote: Ph1 clocks have a cable driven speedo
Not all of them don't - atleast some if not all Phase 1's changed to an electrically rather than cable driven speedo around 1995, but with mechanical rather than the digital odometer as per Phase 2/3's
I shall just buy said phase and and swap watever is in it. Then ninja track car!
Ah I see, I'm thinking of my 94 xtdt which had a cable driven speedo, that's the only genuine ph1 I've stripped haha
what he said, it's only the real early ones that are cable . .Smile
If it has the non keypad centre console I'll buy that from you Tongue
(12-05-2014, 08:50 PM)Matt Wrote: If it has the non keypad centre console I'll buy that from you Tongue
I'll be wanting that myself. Love the storage space
  5 door phase 3 interior parts for sale Teeharv 1 4,245 15-03-2019, 01:03 PM
Last Post: Teeharv
  phase 1 interior. si124 0 1,878 19-03-2015, 07:29 AM
Last Post: si124
  Phase 3 gti6 interior rhyds247 1 2,455 03-06-2014, 08:07 PM
Last Post: WiNgNuTz
