23-03-2012, 08:51 AM
Need to replace a few bulbs in my clocks, what type of leds/fitment are they?
Clock leds
23-03-2012, 08:53 AM
T5 or 286 IIRC (both the same thing)
23-03-2012, 09:00 AM
i've used T5,fit and work - cheap ebay jobbies suffice - but keep the filter
23-03-2012, 09:01 AM
^^ you can replace the filter with rolling papers as the filter is dyed yellow
You can also get the ones with the holder attached such as these which are less of a faff to change http://www.ebay.co.uk/itm/2-X-T5-White- ... 27c4916c0d
23-03-2012, 09:05 AM
yeh those are the ones i bought - a pack of 10 for like £1.99 or something...
23-03-2012, 09:06 AM
I have hdi clocks with white leds, just the temp one went few months back and now my fuel one is flickering
25-03-2012, 10:40 PM
how many bulbs are there?
26-03-2012, 07:26 AM
kentiiboii Wrote:I bought t5 bulbs for mine but mine are twist lock. The bulbs pull out of the holder and they are standard T5 bulbs in them IIRC the only ones that are a single piece bulb and twist lock holder as standard are the ones behind the heater controls
26-03-2012, 11:11 PM
There are some on ebay, advertised as T5, they often say something about B8 in the description. They are the wrong type, I made this mistake, but luckily, managed to pull the LED out and swap that over.
This is the T5 B8, which will not fit the 306
27-03-2012, 09:30 AM
giblets Wrote:There are some on ebay, advertised as T5, they often say something about B8 in the description. They are the wrong type, I made this mistake, but luckily, managed to pull the LED out and swap that over. Why will that not fit?? it looks the same fitting as I remember the bulb holders being............ :?
27-03-2012, 11:02 AM
Iirc the spacing between the metal and plastic where it twists in is larger, I had some but they were fecking hugly spaced!
27-03-2012, 11:18 AM
did you not think to bend the metal tabs a bit closer together?? :roll: LMAO
27-03-2012, 11:20 AM
mark_airey Wrote:did you not think to bend the metal tabs a bit closer together?? :roll: LMAO What I was about to say 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
27-03-2012, 11:25 AM
Connor Wrote:mark_airey Wrote:did you not think to bend the metal tabs a bit closer together?? :roll: LMAO Clearly didn't have his problem solving head on at the time
27-03-2012, 11:38 AM
mark_airey Wrote:did you not think to bend the metal tabs a bit closer together?? :roll: LMAO Didn't even think of that :/ haha TEAM CONROD SHITTING RALLYE!
27-03-2012, 11:39 AM
27-03-2012, 11:45 AM
Matt Wrote:Didn't even think of that :/ haha FAIL..................
27-03-2012, 12:23 PM
Major fail, they have say in the car since, been there for about a year. And now I have plasma dials haha
27-03-2012, 12:26 PM
Matt Wrote:Major fail, they have say in the car since, been there for about a year. And now I have plasma dials haha What colour are they?? you could always post them to me and I will look after them for you
27-03-2012, 12:31 PM
Urm either blue or white. Can't remember. All I do remember is that the led has the tendency to fall out the holder
27-03-2012, 02:33 PM
Matt Wrote:Urm either blue or white. Can't remember. All I do remember is that the led has the tendency to fall out the holder What was that? you want me to PM you my address?? Seriously though, My dash is done with white and blue so either is good for me, if you do actually want rid of them let me know what you want for them Via PM and I will sort you something out
27-03-2012, 03:31 PM
Problem i had with LEDs is after about 5 days they all started flickering like a rave.
27-03-2012, 03:34 PM
D@wson Wrote:Problem i had with LEDs is after about 5 days they all started flickering like a rave. Thats because you bought cheap nasty ones..............mine have been fine for 2 years or more!
27-03-2012, 04:31 PM
mark_airey Wrote:D@wson Wrote:Problem i had with LEDs is after about 5 days they all started flickering like a rave. Where did you get yours from?
27-03-2012, 05:22 PM
D@wson Wrote:Problem i had with LEDs is after about 5 days they all started flickering like a rave. Crazyleds? They are notoriously shit! TEAM CONROD SHITTING RALLYE! |
Wiring footwell LEDS` | JethroJay | 10 | 2,797 |
01-03-2014, 12:06 AM Last Post: JethroJay |
how to wire leds into interior? | CalNeedham3061.4 | 12 | 3,012 |
16-11-2012, 08:40 AM Last Post: C.A.R. |
Tempurature clock to non temp clock | Ben Jay | 10 | 3,262 |
28-02-2012, 09:48 AM Last Post: Foxy-jim |
