Engine mount knock?
Engine mount knock?
What would be causing a knock when the car is started and when you turn it off. Also happens if im drivin, let off accelerator fast and when i floor it fast. Be bottom or top engine mount maybe?
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
idcheck the top mount first to see if the chassis cup is cracked or broken
[attachment=15760]
Yeah was meant to do that but didn get the chance yet.
Hard fixed if it is fooked? Or just a case of goin to a lad with a welder?
weld in a plate Wink
and cover up the shit weld with paint Wink
[attachment=15761]
Cheers ill have a look see is it cracked.
Would of thought thats it on standard turbo, unless your lower mount is pretty destroyed...
I had a knocking in mine and decided to check out the lower mount....
[Image: Image1052.jpg]
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
Was the rubber completly gone like that or you cut it out?
Completely gone. It fell out then I took out the bolt
  Diesel Knock pugtk 2 2,982 16-07-2016, 05:41 PM
Last Post: Mattcheese31
  Top rubber engine mount Pearcey1995 2 2,246 01-06-2015, 06:46 AM
Last Post: gregpurdie16
  Facelift berlingo d turbo rear engine mount problems Jamieh2013 7 4,885 12-05-2015, 05:01 PM
Last Post: Jonny81191
