motor factors
why is some f*ck things up??? i have just found out why my rear damper was on its way after only 3 years.
turned out the lady gardens gave me a cheep shitty basic ones that are not for the HDi,
:evil: propper boils me at times.
has anyone had simular problems with cars they have had in the past and now?
I got given the wrong size ball joint which f*cked my hub
They also tried giving me a berlingo wishbone which is different Undecided
Bloody euro crap parts
i use a few but my GSF in Donny are really well staffed, they know what they're doing and the parts always seem good...
i used ECP once, and they got it wrong, i always go to gsf. there is one round the corner from where i used to live, and when i was changing the engine in my car and getting it mot ready, i was in there everyday for a few weeks. first name basis, and out of all that, only had one wrong part.
rate gsf to the nth degree, so good
Gsf gave the wrong gearbox seal so I lost most of my expensive gb oil! Have had several wrong parts from them!
Jayar have sent the wrong parts to college a few times so we can't complete tasks in the time we have.
I and my local.garage both use Ecp as they are best round here! Smile
Phil the balljoint was your fault, should have measured it before you fitted it
It should be fairly obvious when it's like putting your dick into Connors bum... Very sloppy, not a tight fit and generally a ballache...
Nah, because they do it on registration rather than VIN/RPO they get it wrong all the time, because a car could be made in 1995, but not actually registered until 1997 if it just sits there... Therefore it gets horribly confusing... That's why you see P plated phase 2s and T plated HDis and DTs, from that crossover point, my car was MADE in October 1996, not first registered until April 1997... Making it actually a VERY early ph2...
  Knocking motor factors down spike2002 4 3,160 09-07-2012, 05:30 PM
Last Post: Jenkosowls
