1.9 conversion
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
1.9 conversion
Putting a 1.9 in my 309
Is there any pipes that need changing or anything
Basically do I need anything off the donor car or do I need just the engine?
Team Doesn't own a 306
What are you doing about power steering?
Not sure saxo electric pump I recon
might have to butcher matrix pipes at a guess? . . Smile
I would grab all the pipes you can, then you can cut n shut n join and make what you need. Chuck the rest when its in.
Good plan by the way!
Yea suppose pipes is the only difference really?
Matrix pipes shouldn't be that different really, surely all the 1.8 stuff can just bolt to the 1.9 block. Oil heat exchanger will need plumbing in unless you don't use it and use an oil cooler.
Also use the 18 gearbox saves buggering about with driveshaft issues. Either that or use the 1.9 box and put the 1.8 diff in it
I'll use 1.8 box to save effort lol
Danny look at my 205 build thread its got a walkthrough for the gearbox Smile
Current cars
Subaru Impreza 2.0d - Daily
Ahh I'll hae a look through the thread then mate Smile
Know of anything that needs changing other than what's stated?
Not really just swap all the sensors over so you can use the original loom, more than likely need the 309 downpipe, and thats it really its pretty simple tbh its just the little niggly jobs that take for ever
Current cars
