Knocking sounds from rear suspension
2001 Peugeot 306 1800, Problem - Knocking sound from rear suspension when going over bumpy ground. Seems it is a common problem with this model. What I need is some kind of diagnostic method to nail the offending part and procedure to put it right.
rear mount bushes? does it feel floaty while turning sharp over bumpy ground?
Jack up the rear of car (suppprt on the sills) and move wheel up and down and check bushes and play in beam Smile
(20-04-2014, 07:31 PM)aaronshort Wrote: rear mount bushes? does it feel floaty while turning sharp over bumpy ground?
( I am "newbie" on this forum, still finding my way), Thanks for the reply, no it does not feel floaty, I looked around underneath and together with some diagrams from the internet I can see roughly how the scheme works. From what Ive gathered there are several components that can cause the knocking sound . I am going to put the rear up on axle stands and look for worn parts. Know of any diagnostic procedures ?. Franko
Drop link?
I had the same problem in the drivers side. So annoying!
(20-04-2014, 08:01 PM)beulah Wrote: Drop link?
No drop links on the rear
By Drop links i presume you mean those struts that go from horizontal bar underneath chassis to the shocks. this is front suspension, my problem is rear suspension, anyway those were the first things I replaced.
Rear beam mounts. There's an FAQ on how to do it somewhere
mine was the spare wheel, It had got deflated and was banging round check that area first, also make sure the tyre rack is fully wound up
Also chek that the rubber on the shocks where the bolts go through arent badly perished. Had this happen before.
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
  Near Side Rear Knocking (video included) Tom85 4 3,105 04-07-2016, 07:24 PM
Last Post: Tom85
  Rear suspension, torsion bar to mcpherson Insanity-74 21 11,847 01-01-2016, 11:55 PM
Last Post: welshpug
  Rear beam knocking hotrodjacko 13 7,962 27-09-2015, 10:07 PM
Last Post: Matt
