Sub, Amp and Wiring - £50 at FCS?
Full setup here to get some bass in your car.
JBL 1000 watt sub in box with JBL amp. Wiring kit from the car, correct lengths for 306. 4awg, I think, power and earth cables.
Was in my car but took it out after 4 days as I decided I wanted to hear my engine and that I'm past bassy music in the car.
Can even throw the board for the boot in if you like. I had it bolted to this to keep it stable.
£75.
Collection from South London. Might be going Ace on monday so could bring it with me.
Got any pics of it and is it a 10" or 12"?
It's a 10". Also come with a remote level control for the amp, forgot to mention. Amp model is a JBL GTO 3501.
One of the RCA connectors will need soldering back on as it came off while removing the wiring from the car earlier. I did have a go but our soldering iron isn't great. Edit: think I have a spare set that could go with it.
[Image: 9YSxY82.jpg]
[Image: NlRZnzW.jpg]
Bump.
This is the same sub I have. Would recommend.
Bump.
Got the 8" version, great little subs.
Same sub I have only I've a 4 channel amp bridged running it. Sounds well
Bump.
Bring this to ace with you please...
£50 at FCS?
Bump.
