13-04-2014, 10:51 AM
Central locking via the fob isn't working, changed the Batteries in the fob, checked drivers side door loom, only way to get it to lock is to use the key. Checked all fuses. Any ideas?
Central locking problem
13-04-2014, 07:06 PM
Phase 3? Might need re synchronising with pug plannet as it becomes unsynched pretty quick with no power to keep the code stored.
Team disASTOR? ![]()
13-04-2014, 07:10 PM
13-04-2014, 07:12 PM
Find someone with peugeot planet on here who's local who'll resynch the keys. You should have a blue credit card size card with numbers on and peugeot badge. That's the remote central locking pin. Need the key synched with that number. Then it should all work. If not peugeot will do it.
13-04-2014, 07:48 PM
I have Peugeot Planet if you're coming over Lewis.... Haven't tried re-syncing any keys yet though lol.
14-04-2014, 06:41 AM
Just make sure you have the code guys if not http://www.carkeycodes.co.uk
Use him ^ very quick response on text sorted mine out in 10 minutes
14-04-2014, 09:30 PM
(13-04-2014, 07:06 PM)Razorback_Rob Wrote: Phase 3? Might need re synchronising with pug plannet as it becomes unsynched pretty quick with no power to keep the code stored. Not quite true. The pairing codes are not stored in a volatile memory so will never be lost when the battery has been off. Some times though it can go out of sync so you have to resync it which does not require peugeot planet. Its just a sequence to do with pressing the buttons and turning the key but i can't quite remember what you have to do lol
14-04-2014, 09:55 PM
(This post was last modified: 14-04-2014, 10:14 PM by Razorback_Rob.)
(14-04-2014, 09:30 PM)Niall Wrote:(13-04-2014, 07:06 PM)Razorback_Rob Wrote: Phase 3? Might need re synchronising with pug plannet as it becomes unsynched pretty quick with no power to keep the code stored. Ah I was told by my friend who had his 1.4 phase 3 remote central locking re-paired by pug and the guy said was volatile and my mate watched him program the key with the car. Typed a code. Entered key and turned. Removed and did on second key. Then they worked. The resync button sequence works apparently only if you change the battery in time that information isn't loss. I'm just the messenger telling what peugeot told a mate who's told me. Obviously the old ir system was much easier to sort out when the plip wasn't working if only method was the same. But do try the rf 306 method it's somewhere on the forum like Niall said. No luck for me. Luckily me and ozonehostile are getting our hands on a laptop with pugplanet on see if it works or if it's bull. Can't hurt to try though.Also he warned on pressing the buttons repeatedly when not in range of the car as this can also desynchronise too apparently.
Team disASTOR? ![]() |
| Central locking/deadlocking/immobiliser going beserk. | pug306driver | 5 | 6,258 |
29-01-2022, 09:29 PM Last Post: pug306driver |
| central locking bypass auto unlocking | andyw | 1 | 3,695 |
04-07-2021, 03:58 PM Last Post: Mighty306 |
| Universal remote central locking | carrot | 1 | 4,218 |
19-02-2021, 07:58 AM Last Post: Mighty306 |
