12-04-2014, 02:45 PM
Does anyone have a standard radio to put in a 306, i want to change mine due to it not working but i like the standard headunit, would also help if had pin number
Wanted: Standard 306 cdplayer headunit
12-04-2014, 02:54 PM
I've got one I'll have to check for the number..
12-04-2014, 02:55 PM
reading up on here, all is needed it the serial number sticker to be on it still
13-04-2014, 08:08 PM
Anyone?
13-04-2014, 11:15 PM
I have one, how do I get then out? Or is it just like normal hu?
14-04-2014, 05:13 AM
Depending on which headunit it is, either it will have 2 holes each side to stick nails in and pull out, or if you look along the bottom edge, ill just see 2 cut outs about 15-20 mm long, you need to get a couple of small thin bits of steel in there to pop the bottom clips.
14-04-2014, 05:43 PM
cool thanks
14-04-2014, 06:00 PM
Im also after one of these for the rallye if anyone has one cheaps (obviously once Matt has one)
14-04-2014, 06:07 PM
i think i have two or three of these, will check if they have codes
14-04-2014, 06:47 PM
(This post was last modified: 14-04-2014, 06:47 PM by mattgreene.)
Ok then thanks chaps
Codes are easy to work out from the serial number
14-04-2014, 06:53 PM
There's one on back of my dad's 6 woo see what he doing he it as well. Not had chance to get other out of the 6 yet.
14-04-2014, 06:54 PM
Ok mate
19-04-2014, 11:47 AM
anyone?
19-04-2014, 11:59 AM
I've got a standard CD changer if that's of any help
19-04-2014, 12:04 PM
(This post was last modified: 19-04-2014, 12:04 PM by mattgreene.)
not really! i just need a replacement headunit!
but thanks |
Wanted: Cheap P3 Standard Headunit | C2K | 17 | 1,942 |
01-02-2014, 08:29 PM Last Post: Nadine |
