Things to check on a modified Bosch
I've seen a pump on ebay for cheap. but doesnt come with injectors and lines.
I think he wants at least £50 for it.
However i've been speaking to some one who has a modifed pump with lines and injectors for about £70.
What would be the cheaper option?
What should i look out for on the modified pump?
Buy the complete setup it will save a lot of hassle
Current cars
Subaru Impreza 2.0d - Daily
td_dan Wrote:Buy the complete setup it will save a lot of hassle
this . .^^^^^^ . .Smile
ok! lol
what should i be looking out for on the pump?
He said the gov mods been shimmed 0.5mm.
same one from the seller with godawful feedback?
^think that one has been updated to say it includes injectors and lines.
zx_volcane Wrote:same one from the seller with godawful feedback?
No its another one not through ebay. Looked at it but i cant afford to pay more then £80 for the whole set up
A 0.5mm shim on the gov seems a bit.... little?
Captain Standard
0.5mm shim on the gov? Thats not going to increase the fuel cut by a huge number of rpms tbh, and is that the only thing thats been modified? Either way, the complete setup is going to be cheaper / alot less hassle in the long run provided hes not screwed the pump up...
enless he means 5mm
im not clued up on what a gov mod actally is
Ben Jay Wrote:enless he means 5mm
Join the club mate, I feel like such a noob when it comes to modding fuel pumps/turbos. Sad
If I've understood it right, the governer stops fuel at a certain rpm to avoid engine damage (and fun....)....the gov mod allows it to keep fuelling so you get a bigger rev band. Someone correct me.if I'm wrong as I'm currently doing an assignment on VE systems. lol
Toms306 Wrote:If I've understood it right, the governer stops fuel at a certain rpm to avoid engine damage (and fun....)....the gov mod allows it to keep fuelling so you get a bigger rev band. Someone correct me.if I'm wrong as I'm currently doing an assignment on VE systems. lol
In principle, yes.
As engine rpm increases, centrifugal pressure is exerted against the governor. This then compresses the springs within the gov cradle, which in turn begins to limit the throughput of fuel within the pump..
When modifying the governor, a 'shim' is put into the main spring, which makes it much stiffer (some people even do solid). This means that when the same centrifugal pressure is applied at higher engine rpm, the governor resists this movement far more, and thus the fuelling is not decreased.
Why not just fit a stiffer spring instead of shimming the stock one I hear you say? Because finding one which would fit perfectly would be a pain.
There are other modifications which you can do to the governor assembly which Dan! and myself did to my pump, the credits of which I believe go to Dave (HA11). However these are top secret ninja
Captain Standard
^... Most of which are probably available from vwdiesel.net or elsewhere..!
People wanting to mod boschs for dturds need to read outside of these 306 forums where this 'knowledge' is kept secretive.
[Image: brokendown-1-1-1.jpg]
Dturbo GT2259s build thread;
Haha hardly secret, just some parts have more travel than others, which can be found in different pumps. But your right, the internet is full of other places where the VE is applicable, and give much better/in depth info on modding. Seek and ye shall find.
Dave Wrote:Haha hardly secret, just some parts have more travel than others, which can be found in different pumps. But your right, the internet is full of other places where the VE is applicable, and give much better/in depth info on modding. Seek and ye shall find.
Relatively secret/quiet is more apt i suppose Smile
I don't think it's a bad thing though, as i think it's important people learn how the pump works then apply mods knowing wtf they are actually doing and why.. rather than being told do x y z. More fun!
Yeh exactly Wink people should not be confined to this forum while learning how VE's work, if they do their research elsewhere, would realise that its not really secretive at all.... so its laziness in some ways...
Right my pump arrived! Is there any thing I should do to it before I put it in the car? Any bits that should be serviced or looked at? Also Ill have to check what the gov mod actully is!
Any one?
In principle, yes.
Was that the tranny throttle/gov arm and cradle and gov you used? Slightly bigger isn't it
Sent from my HTC Wildfire using Tapatalk
[Image: sig-1.jpg]
SOLD
Just the transit cradle. Throttle arm and gov assembly wouldn't work/give any benefit from what I could see! Smile
  Are KCA 17S42 Bosch injectors rated at 175bar ok for my modified XUD? 399road 4 3,379 11-04-2017, 03:33 PM
Last Post: 399road
