Crankshaft sensor relay????
just wondering is there a relay for the crankshaft positioning as im getting no power to mine????
any help would be appreciated
check the wires back to the ecu for continuity as they are known to break with engine vibration
(09-04-2014, 07:24 PM)cully Wrote: check the wires back to the ecu for continuity as they are known to break with engine vibration
will do thanks Smile do you know can i bypass the crank sensor??
  HELP HELP HELP crankshaft sensor not getting power shanecox14 5 2,957 08-04-2014, 07:43 PM
Last Post: Niall
