Hello ,
i have a citroen bx , started work on it a while ago , it`s easyer to check the history here ... http://www.nosmokenopoke.com/forum/showt...troen-Bx-D
Now the car has a new setup with new parts , new camshaft , new clutch , new injectors , new engine(with stock parts),vibratechnix engine mounts and so on , the car i am making for drag racing only , hope it will be in lower 12 maybe high 11 sec only diesel and turbo . Then maybe lower ... depending on the performance of the gearbox ) i cracked a lot with less power ...
In progress is a peugeot 406 as you may know it with nitro - i will keep track of it here after is done (after 1 gearbox and 3 driveshafts we decided to put bigger turbo and a LSD )
And another citroen bx with aircon full street with 1.9 td and over 200hp , still buing parts for it .
All parts are made in our shop , or in a friends shop .
[attachment=14975]
[attachment=14976]
[attachment=14977]
[attachment=14978]
[attachment=14979]
[attachment=14980]
[attachment=14981]
[attachment=14982]
My bx was 233bhp , unfortunetly injectors were the problem a few years ago , now i cracked the problem and put nozzle wich can flow 100hp per piece . Hope the gt35 turbo does the job of making the most powerfull xud . If i can find a way to make the conrods i am sure i can go much higher ...
[attachment=14974]
[attachment=14975]
[attachment=14976]
[attachment=14977]
[attachment=14978]
[attachment=14979]
[attachment=14980]
[attachment=14981]
[attachment=14982]
[attachment=14974]
