Threads: 68
4
Car Model/Spec: 306 HDI
Given 1 thank(s) in 1 post(s)
hi guys,
just a quick one which is probably going to sound silly..
basically noticed an espace with a vented splitter in scrapyard while i was getting some parts for a corsa and decided ill have it..
i have never fitted a splitter before so was just wondering the best way to attach it and do i need to cut it down?
can it be attached the same as a gti6 splitter with clips and screws?
if anyone could help i would appretiate it
thanks all
Threads: 169
91
Car Model/Spec: 2003 Jaguar S-Type Sport 3.0V6
I have an espace splitter on mine. Check my thread
To be truthful, I just used self tappers through it and the bumper, and that's held fine for ny-on 3 years now. It gets scraped a lot too...
Threads: 68
4
(03-04-2014, 06:59 AM)Grant Wrote: I have an espace splitter on mine. Check my thread
will have a look mate, is it on your project thread?
mine wont be that low just thought id ask or whether its better to use the gti6 splitter fitment idea?
do i need to cut the splitter for it to fit or will it go straight on?
thanks
Threads: 208
60
Given 5 thank(s) in 5 post(s)
it needs to be cut and screws will be fine
Threads: 169
91
(03-04-2014, 02:58 PM)mspdan Wrote: (03-04-2014, 06:59 AM)Grant Wrote: I have an espace splitter on mine. Check my thread
thanks
My project thread yeah
If it has never been on a 306 before then will need cutting as puglove said
Threads: 68
4
okay thanks,
not really 100% sure but im sure i can find someone to show me as im not sure what im cutting, is it out the centre or off each side?
thanks
Threads: 79
17
Car Model/Spec: Down and out HDi racestate
Given 0 thank(s) in 0 post(s)
Hold it on, maybe use some pegs if your by yourself and you will be able to see where it needs cutting.
Threads: 169
91
Off each side!
Mark the centre with tape, do the same with the bumper, screw it on, then trim to fit with it on
Threads: 68
4
(03-04-2014, 07:39 PM)Grant Wrote: Off each side!
cheers, sorry for being slow, one of them days :/
Threads: 21
0
Hold it on using mole grips or clamps, mark the position so that it is in the middle. Mark where your middle screw will go. Mark the ends.
Take splitter off, drill pilot holes using small drill bit.
Cut off ends.
Clamp back on, postion correctly, get on your back and get screwing
You could just trim it off the car and then screw it in almost all the way around and then cut of the excess with it on the car. Use a good hack saw. You can determine the shape better with it on the car, follow the curve of the bumper.
Threads: 169
91
04-04-2014, 11:13 AM
(This post was last modified: 04-04-2014, 11:13 AM by Grant.)
(04-04-2014, 11:12 AM)HD-Aye! Wrote: Hold it on using mole grips or clamps, mark the position so that it is in the middle. Mark where your middle screw will go. Mark the ends.
Cut off ends.
The plastic is so soft, you would get a better cut with a new Stanley blade than a hacksaw.
Threads: 21
0
Have to be a warm day and a bloody sharp knife
Threads: 169
91
Or just a stanley knife, whenever
Its piss easy to cut, A hacksaw would leave you with burred edges, a knife, not so.
Threads: 102
18
Car Model/Spec: Ph.1 Gti-6 63k
Given 22 thank(s) in 22 post(s)
You can easily cut laguna/espace splitters with a sharp knife. I did it with a penknife...
62k Diablo Phase 1 Gti-6: Project Thread
Threads: 21
0
Furry Muff
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
I'd be using zip ties personally.
Threads: 79
17
