Wanted: Roof gutter strip
Not sure if they differ between phases, but phase 3 if so.
Not sure if they differ between sides, passenger side if so.
PM me some prices posted. Smile
I've a pair of colour coded black ones from a early ph2?
[Image: sig.jpg]
Would you measure the width, length and depth for me? Then I can check it'll fit. Smile
How much did you want?
Ph 3 ones here. Are you still wanting one?
All gutter trims fit the same.
After £20 posted.
[Image: sig.jpg]
The ph1 strips was solid metal, ph3 where mostly hard rubber with a in grove on the top Smile Ph1 strips ftw .
  Headlamp Adjuster, roof strip RetroPug 0 1,443 04-04-2014, 12:23 PM
Last Post: RetroPug
  Wanted: Rear passenger side strip in black deggerz 13 6,474 03-04-2014, 09:45 PM
Last Post: kentiiboii
  Wanted: Black rear passenger door sode rub strip deggerz 2 2,093 03-12-2013, 02:39 PM
Last Post: deggerz
