S16 exhaust options
I've heard the gti-6 manifold doesn't fit for both width & port sizes...
Is this true? Is there advantage of upgrading over the standard exhaust?
What 'cheaper' options are there to upgrading the exhaust?
Your right the 6 manifold use's different port spacing and shape along with 1 stud being different too, Not allot can be done other than replacing the manifold as the cast iron one is restrictive coming from the old 1.9 base engine it was just done to be cheap at a guess. I do a 4-2-1 manifold for these but it's not cheap to the low demand of them at £400.00 in mild steel, Without knowing the spec of engine etc any gains are hard to say but with a basic tuned engine, T/B's, Reground cam's these see a good 10bhp gain along with mild range torque
Ahh bugger lol
Is it a big job to port the head to fit or cut the welds and cut a new plate to fit?
I'm not looking at massive gains just (yet), I'm going to try and get my hands on a gti inlet, pop on a decat/less restrictive exhaust and an induction kit...
git gti6 engine, instant 12 bhp gain, and about 12 lbft.
Nothing wrong with the s16 inlet if it's all working correctly
Can do things like remove some material from the inner edges of the throttle body as there is a fair step down.
Match that to the diameter of the inlet manifold and the 8 inlet ports open out to the size of the gasket, all helps
As for a decat I had both a single type version and a twin pipe version, the twin was a Peugeot sport group a item and was far better than the sing he pipe version, either are hard to come by now though
You really need to remap it if fitting a 6 inlet the difference is that large, But the basic tuning is better than a 6 with Cams being a easy fit etc
(01-04-2014, 06:54 PM)welshpug Wrote: git gti6 engine, instant 12 bhp gain, and about 12 lbft.
Not a massive option, had a spare engine for me previous pug but lost interest in that idea... Heard the s16 had better bolt on options so thought I'd get it for the long run...
(01-04-2014, 08:28 PM)swampy Wrote: Nothing wrong with the s16 inlet if it's all working correctly
Unfortunately the vacuum pipes snapped on the diaphragms, and it was an absolute b*****d trying to do things in the engine bay with such a large inlet, that was the main thought behind replacing to a gti manifold - I did love how it took off after 4k though..!!
I was going to port match & polish, the head & all manifolds are off - thought I'd dropped a valve...
What are other noticeable differences with driving does a gti vs s16 manifold have? Any mpg? If it's sucking half the volume of air does that make a difference?
You got any photos of the twin decat?
I'm tempted to by some mild steel and see if I can't rig a jig with my old manifold to make a custom branched one... Any comments haha
(01-04-2014, 08:34 PM)miles Wrote: You really need to remap it if fitting a 6 inlet the difference is that large, But the basic tuning is better than a 6 with Cams being a easy fit etc
Oh really!! Wow nice! Where can you remap a standard ecu or would I be looking at the omex/mega/emerald route?
The decat runs from the manifold join to the exhaust join replacing the cat.
Get your self a new pair of diaphrams and get them set up correctly it really is a fantastic inlet when it's all working correctly.
I don't think it's actually that much bigger than the gti6 item .
Ahh just looked at a few more photos and the black inlet looks deceivingly larger, think your right about the same size lol ... I'm tempted now, where can I get new diaphragms (and probably a new gasket) from?
You may hear from me about getting it working properly (saw your post about it!)
I've got a decat on my current pug but I was confused with the difference between a twin and single decat?
Diaphrams your looking at second hand or new from pug don't think any one else does them.
Inside the exhaust manifold and standard car pipe is a diveder, a single tube decat has this in aswell ( if you get a decent quality one) a twin tube is just that instead of a divider it has two tubes
I can't seem to get hold of any diaphrams. I rung peugeot last week and they said they can't get them anymore
Ahh bugger! I saw on service box they're £30 each as well ... Looks like I'll be trying to carefully prise and repair!
Is there a guide on diaphragm repair or shall I get my camera out?
Ahh I get you now swampy, can you remember how long the twin pipes were, I'm tempted to have a play at making a full system!
I was expecting them to be more that £30 tbh.
There was a magnex exhaust system on eBay a few weeks back with the twin pipe decat. Was brand new old stock. I wish I bought it really
(02-04-2014, 09:44 AM)Frosty Wrote: I was expecting them to be more that £30 tbh.
you should of done, was by far the best thing i fitted to my s16
strutbaces are good aswell, really sort the front end out.
I was thinking it would go pretty cheap as not many s16 about. It went for £150 ish but I suppose that wasn't to bad as was brand new. Maybe kicking myself now Sad
Drop me the part number as I know someone who has a few contacts in Europe so if there are any he will find them,
The 6 inlet has longer runners over the S16 one which are short, Also the TB is allot larger too.
  exhaust options ? jjenn20 1 1,747 13-02-2015, 09:11 PM
Last Post: luke306rallye
