Immobiliser
Now that I'm not using the original ECU, i no longer have an ECU and having to remove the ECU every night so the car can't be driven away is a right PITA lol.
Ive been looking at the wiring diagrams and I've found the following:
Cable 820 travels from the BSI to the ECU pin 13
Cable 821 travels from the BSI to the ECU pin 27
Both have a typical state of 11-14v when the ignition is on but what I'm wondering is if i could use the two to control a relay and if so, are these cables live all the time when the key is present and ignition on or is it just a pulse?
If anyone has any info on how the standard immobiliser works, id be grateful to see it Smile
Thumbs Down Immobiliser thebluepearl 11 5,955 20-05-2016, 12:05 PM
Last Post: insomaniac45
  Xantia 1.8 16v key/immobiliser Piggy 7 5,461 26-02-2016, 04:02 PM
Last Post: Toms306
  immobiliser problems roemer 5 4,382 21-09-2015, 10:41 PM
Last Post: Pug30614
