Replacing rear beam mounts
While the beam is off my gti6 I figured now would be a good time to fit some new mounts.
The square one is as simple as it gets to replace, however the front mount (with the two bolts) is causing me a bit of bother.
Basically, how do you get the bottom bolt out far enough to get the mount off? As it only comes out a couple of inches before it is obstructed by the trailing arm.
Am I missing a trick here, as far as I can see, the only way to get the bolt out far enough is to pull the arm out?
You have to force the trailing arm down and drift it out with another, longer bolt. It is a ball ache, but do-able
this might help pointers from when i did it Wink
http://306oc.co.uk/forum/thread-13188-po...#pid283654
Looks like it's easier when the beam is on the car from the way you did it cully, I think I'll do the same as there's something to push against then rather than rolling around on the floor.
Cheers for the guidance fellas, rep accordingly
Still waiting on mine whistle
Thats better
Wink
Makeup
Long punch and a hammer had never let me down Smile
That's a nice thread cully as I may need to do mine soon, need to check at zachs next weekend as it's an mot failure Sad
[Image: siggy1.jpg]
Best on or off the car Frosty?
I found it easy enough getting mine out off the car mate don't really remember how I did it without looking though lol
/unhelpful post
Got any spare mounts just incase Zach?
[Image: siggy1.jpg]
il have your fobared mounts Smile
(27-03-2014, 08:28 PM)cully Wrote: il have your fobared mounts Smile
So what is cully building..?
[Image: siggy1.jpg]
Nothing whistle
[attachment=14709]
(27-03-2014, 07:27 AM)ozonehostile Wrote: Best on or off the car Frosty?
Ive done them both on and off the car before. Just need to let it know whos the boss
Haha, I'll have another crack at them again tonight
Sounds like fun mate Smile
[Image: siggy1.jpg]
(27-03-2014, 10:37 PM)cully Wrote: Nothing whistle
I was thinking about doing this myself, when mine eventually fail.
How harsh are they?
How harsh are they?
not fitted them yet
What are they for cully?
[Image: siggy1.jpg]
maybe the six if they fit Wink
Homemade solid mounts?
[Image: siggy1.jpg]
(28-03-2014, 07:13 PM)devils_fuel Wrote: Homemade solid mounts?
Maybe Wink
[attachment=14712]
Very nice Smile
[Image: siggy1.jpg]
Any bracing inside them cully?
(28-03-2014, 10:23 PM)anto Wrote: Any bracing inside them cully?
no there is no bracing inside, but once i clean them up and paint them, i will probably fill the void with silicon or somthing to stop water getting in and rusting them
  Rear beam ...the good and the bad Mighty306 35 30,464 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,309 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 15,342 18-03-2019, 03:40 PM
Last Post: MOK
