Not so common central locking problem
My key fob is broken so i only use the key on my ph1. However, the key only locks/unlocks whichever door i put it in. Same story inside the car... if i push the drivers lock down, only the drivers door locks. I've tried searching in this and other forums and google and all i can find is people who's doors all lock and then unlock again. Anyone help?
it'll still probably be broken wires in the door looms, first port of call mate, cut the rubber off (carefully and check for breaks . .Smile
Cheers, will try that tomorrow Smile
check your fuses.
I was going to check them, but it was too dark =/ again, i'll do that tomorrow, thanks Smile
has same problem with electric window drivers side, as well as drivers side speaker and passengers side elec mirror....found realy bogged repair to broken wires, soldered ( with old fashioned gas heated soldering iron and heat shrink ) and now all good....apart from key fob locking which used to work till we fitted new batteries..........however car getting better as small jobs being done one by one.........
My passenger speaker doesn't work either. My pug doesn't have electric windows so one less thing to go wrong i guess... And my keyfob is completely knackered... Im in the same boat as you withall the little jobs Smile
  Central locking/deadlocking/immobiliser going beserk. pug306driver 5 5,965 29-01-2022, 09:29 PM
Last Post: pug306driver
  central locking bypass auto unlocking andyw 1 3,557 04-07-2021, 03:58 PM
Last Post: Mighty306
  Universal remote central locking carrot 1 4,069 19-02-2021, 07:58 AM
