1.8 to gti6 conversion
hi there, i know there are probably a few threads about a gti6 conversion but i was just wondering if i got the complete engine, ecu and wiring loom would there be anything else that i would need, other than the supension, brakes, clocks
The exhaust downpipe is different. So will be the radiator and power steering return pipe. Depending on your car you may have an a/c compressor that you don't need on the new engine and the heater matrix pipes are different Smile
That's everything covered I think, by suspension I presume you meant rear beam also?
For the down pipe, I've got both a decat and a cat for sale, £20 each Wink
(24-03-2014, 07:15 PM)Matt Wrote: That's everything covered I think, by suspension I presume you meant rear beam also?
yea i did include the rear beam aswell
and i may have the decat off you il find out tomorrow
Sweet deal mate, if you need any other parts lemme know. I've got a fair few '6 parts lying around I'm getting rid if dirt cheap
  Turbo conversion gti6 kentiiboii 36 19,799 10-01-2015, 09:13 PM
Last Post: fatlapit
  1.6 8v to gti6 conversion ?? Jukie88 19 15,673 23-08-2012, 08:12 AM
Last Post: THE_Liam
