Stage 2 moonstone hdi
Here is my 1999 306 hdi in moonstone.
I have owned this for the last 6 months and is now time to pass it on as I need a bigger car.
It's had lots of bits done to it as I brought it standard.
And the mileage is at 146000 and still running nice.
It never let me down the car tax up the end of the this month and mot I think is 6 months left I'll have to check.
List below.
*Cambelt kit done 5k ago.
*full service including oil filter/oil/air filter/fuel filter/forte diesel treatment done 1k ago.
*Rear bottom arm bushes done 1k ago.
*had new fan belt tensioner done 5k ago with cambelt kit.
*its had new fmic and pipe work.
*whippy stage 2 map.
*manual boost controller.
*egr completely removed and blanked.
*exhaust decated and rear box removed done by long life.
*its been lowered between 30-60mm on shocks and springs carnt remover make.
*boost gauge.
*has voltage gauge (not wired in)
*hydro dipped centre console clocks surround door handle surround in grey and black camo effect.
*wind deflectors.
*will come with centre air vent pod.
*17inch alloys not sure what that are but look nice.
*set of cyclones wich will need new tyres.
*quick shift gear leaver.
*hids
*led sidelights and number plate lights.
*hydro dipped wing mirrors and scuttle panel in the same patten as interior.
*gloss black fuel cap cover strips.
*uprated speakers all round looks oe.
I strugerling to think of the other things but proberly missed loads.
Now the bad bits all have them.
List below.
*The rear axle has camber but come with a good axle and a bearing kit wich I was in the middle off stripped down ready for the new bearings to go in.
*The rear bumper has a few scuffs was like it when I bright it got another one to go with the car.
*and the clutch has just started slipping.(I still drive it daily)
* and the front seats are leather leaf pattern and the backs are standard blue black and blue.
And to be honest apart from needing a new rocker cover that's all.
Oh and it's only got 1 key.
I'm looking for £1100 I'm near Coventry any questions fire away thanks.
[attachment=14504][attachment=14503][attachment=14502][attachment=14501][attachment=14500][attachment=14498]Hopefully some better pics
No one???
A bit of advice, I'd completely rewrite you advert.
It's quite difficult to read, give more information about the car, not just what mods its got.
Is there a price, that might help..?
Good call I'll rewrite it when I finish work and also looking at others it's got to worth a£1000
Now fitted new cg 5 paddle clutch kit and new rear axle and car raised to standard ride height.
Also put 4 toyo proxes on it and a new spare tyre.
And drilled and grooved disks and pads alround using mutex pads.
Only things that need doing is the front arches if you wanted to?
And had new dogbone mount.
And has had a black head lining inside.
And 6 months tax
Can also supply full lowering set up with it shocks and springs and axle all set to the right height.£1100
  Low Mileage Clean Moonstone Stage 1 306 HDI td163 11 9,242 13-02-2016, 07:22 PM
Last Post: roland rat
  Moonstone stage 2 hdi karl1989 19 10,061 01-06-2014, 09:46 AM
Last Post: karl1989
  306 hdi moonstone stage 1(deposit taken) kentiiboii 10 7,307 15-03-2014, 11:40 PM
Last Post: kentiiboii
