Reverse lights and Speedo problems
Reverse lights on my brothers 3 0 aren't working he's checked the bulbs and wiring, could there be a fuse or something at fault?
Also I put up a post the other week regarding the speedo, it use to jump about but now it doesn't work at all. I checked for the usual speedo sensor and cannot find one at all id a spare gearbox sitting and was using the location of it to help me look for it and couldn't pretty sure there isn't on it and hasn't been as the speedo use to work fine up until about 2 weeks ago, I replaced the white sensor (one at the front of gearbox that's easily got to) and its not helped could the clocks be duffed or there a fuse to check for the clocks?? Its a 98 D-turbo
  reverse sensor pugtk 1 888 01-05-2013, 10:18 PM
Last Post: londondan86
