307 HDi fault
307 HDi fault
Star
Got my new daily 307 HDi 02 reg nice a cheap cus it's in limp home mode the code is p0193 fuel pressure fault any help thanks
Was cheap for a reason then.... gotta be a fuel pressure sensor of some sort, James should have a couple to swap with??
I thought it wad a fap fault??
[Image: av5ym8.jpg]
Won't be the fuel pressure sensor, more likely the fuel pressure regulator or the fuel pump. Read the FAQ section on my website, lots of useful info on there.
HDI Tuning Ltd
www.hdi-tuning.co.uk
I understand he.found the fault now, very odd one.
Ill let him explain
[Image: av5ym8.jpg]
Yep found the fault in the end bit of a strange one think someone been playing traced fault back to a broken pin on ecu runs fine now temp repaire for now will sort proper when got time still a little jerky when driving but hasent been service in a while I would say
